AutoRun??
m1ck97
Ok... I have been having this problem for a while now - where when i put a CD in or my Pen Drive - nothing comes up, my cd doesnt spin and my folder is supposed to come up when I put my pen drive on (which at the moment doesnt)
What is wrong?? I dont think i have changed a setting but it is quite annoying to have to go via my computer to view the contents when i plug my pen drive in or insert a cd.
Thanks in advance
Thanks in advance
Right click on the drive ---> Properties--> AutoPlay Tab and enable it from here.
i don't think this helps because i have the same problem too. i'm pretty sure that its a registry error, if you fix it tell me.
I've already tried this. There isnt just an 'enable' option 'I have the prompt me each time to choose an option' checked, but have also played with the select an option to perform, neither work.
