WhiteZero
- Oct 21, 2004
Now that AutoPatcher is shut down, can anyone recommend an alternative? Other than Windows Update...
I know what Autopatcher is. It's also used to save time after a fresh install so you don't have to redl the updates. So I recommended a slipstreamed cd. If you want to completely do away with WU then there is a program that grabs the updates for you but I can't recall the name.
WSUS
I haven't looked into it, but it shouldn't be too hard to start making unofficial updates to the last core version.
