Has anyone thought about using an automotive electric waterpump in their PC? The flow rates are insane at 35 gpm, but I was thinking that you could reduce the amps going to the pump and make it flow at a much more reasonable rate. This would in turn reduce the noise and heat generated as well. They seem pretty high quality compared to the pumps used for fishtanks. At www.summitracing.com they have a Proform Electric Water pump that is blue or red anodized aluminum for $139.88.
http://store.summitracing.com/defau...=bysummitpart&searchtype=both&part=pro-66225_
Here is a pic of what it looks like.
http://www.proformparts.com/parts/66225.html
It's listed at $149, but in the Summit magazine I just got, they are on sale for $139.88. This is a little more than the high end fishtank pumps.
