I am trying to find a way to generate an image (or something) of a hard-drive (C:\ drive) while it is running / in-use (without interruptions) on a PC automatically & silently when I connect my USB drive (or with as little intervention as possible) - the installing is Windows XP (in case that makes a difference).
Long story short, there are PCs with no keyboard, mouse, or monitors and I need to make images of them - so simply connecting my USB HDD and having something automatically kick-off would be the ideal goal.
Anyone have anything to recommend?
Thanks,
Thanks,
