automatic fan speed for gfx
xnikx
Is there any tool i can use so that i can make my gpu fan go to 100% only when the card hits 70C?
Sure can.... for ATI cards, use ATItool. For Nvidia... is it nTune? Someone with a Geforce help this guy out!
i dont think u can do that with ntune, i kno u can set the speed but i dont think u can make it so it does it when u hit 70C
some1 suggested RivaTuner, never herd of it. Does it work and can i trust it?
And can i use ATI tool for my nvidia card?
I just downloaded the latest version of ATI tool for a friend's computer... and noticed... YES they support nVidia cards now!
quote: All NVIDIA and ATI cards except for Radeon X1950 Pro are supported in this release.
yay!
can i get a link were i can dl it? and maybe a guide that shows me how to set the fan?
http://www.techpowerup.com/atitool/
There's the link... once loaded you want to click on "properties" (or was it settings) at the bottom of the screen, from there, the drop down has several more options. Go to fan control and check the box to override factory settings.... the rest should be self explainitory.
Don't forgot to go to the startup section to make sure ATItool is loaded with windows at startup.
Once you load up the program it will have the default profile loaded.... create a new one (it's ok if the clock speeds are the same), and give it a name... make all your changes (don't forget to set your new profile to load at Windows startup), and then click on save (to save profile, and then click load).
i dont kno anything about volts and stuff, like how much i should have. all i wanna do with ati tool is make it so when my gfx card hits 70C the fan will go to 100%.
Load it up and take a look at the fan control section.... as I said, you will have to check the box to override the factory settings, but you can have your GPU fan run at 100% all the time if you wish... or set it for different percentages depending on temps...
Like I said.... it's pretty self-explanitory.
i just want it only when it gets to 70C. i wont be able to install it tell my mobo comes for my other comp. I had to RMA my mobo, right now im on my sisters comp.
Well... you can still load it onto her computer just so you can take a look at it... and you can uninstall it when you get your system running.
Or I can come out and install it for you.... I charge $75 an hour.... plus travel expenses. ;)
