rogue_jedi
- Sep 6, 2002
**Zip at bottom of post**
this should install FAH502-Console automatically, as a service, into C:\Program Files\FAH. but we'll see whether it actually works or not
here's the files you need: (copy+paste into notepad, then save as the appropriate filename)
just go download the zip please
put all those files, as well as FAH502-Console.exe, in a directory other than root of c: and c:\Program Files\FAH. i don't know how well it'll deal with that yet...
and sorry it isn't more automated, this is just something i did in ~30 minutes. i'm looking at NSIS (at the suggestion of my brother) for a better version. i'll let you know (here) when/if that becomes available.
edit: started glancing through NSIS...
it'll be awhile before i get that done
edit2: apparently it (vbulletin) doesn't like long strings of characters, so the reg key is broken. if you can figure out which spaces to remove, that'll work, but i'm going to find a host so the files can be downloaded properly.
edit3: http://free.angeltowns.com/roguejedi/fahsetup.zip
edit4: fixed reg key, made it silent (doesn't prompt for reg key)
