autofeed dvd optical drive.
Not sure it's called autofeed, but it's basically the kind of CD/DVD player you find on macs or on car stereos, where you put the CD/DVD into a thin slot and it'll grab it and insert the disk itself for you. Basically a CD/DVD drive with no tray. Does any one know where to get one of these? I know about invisiable optical trives, but it'd just be much easier for my case mod if i didn't have to deal with hiding an entire disk tray.
They're called slot-loading drives. Search around a bit and you'll find a few different ones.
Pioneer have always made these. I would recommend them but I have no experience with their products. I believe they can scratch double sided discs.
