I happened to launch Gigabyte's Easy Tune 6 this morning and found something horrifying. The motherboard is setting the VTT to 1.5v and VPLL to 1.7v by itself. I went straight into the BIOS and start checking every voltage settings on the menu. Prior to this discovery, I've only fiddled with Vcore and DRAM voltage to stabilize my OC, and I left everything else to AUTO, thinking that it would keep all other voltage settings to default. I was wrong.......so damn wrong.
It turned out that the VTT and VPLL voltages were overvolt by a large margin, which could potentially lead to hardware degradation To sum it up, I've been running my CPU with dangerously high VTT and VPLL voltages for over a month, including multiple stress test sessions, I can only imagine the damages has been done.
just a heads up, please check your voltage if you are OCing and have voltage settings set to AUTO in BIOS.
