Audiogy 4 owners need quick help.
Isaacav2
While I was installing my Adiogy 4 drivers, my computer stalled during the installation and I had to force restart the computer during the installation. When my computer rebooted I noticed that my drivers were installed but that was it, no sound testing software or any other goodies that can come with a new soundcard.
Could you... Go into add or remove programs and tell me if you have other audio realated programs that came with your soundcard installed? Also my Mic doesn't work, could the messed up installation have caused the problem?
Should I reformat my computer and reinstall everything?
Thanks Isaac.
Hardware devices and uninstall.
Anytime you lock up during a install its no good.
Soooo since I see nothing in add or remove programs, I should go to my device manager and uninstall sound drivers from there and see if I can do a full installation all over? I do think that I hear audio hitching indicating that something is not right. Should I uninstall from device manager or should I just reformat the HDD?
