drleospaceman
- Feb 12, 2009
Are the A5's good for gaming, mostly in terms of bass? I've been searching around but haven't found a gamer's opinion. They'll be used with a xonar sound card.
I was just noticing, do they not have a headphone out jack?
I have a pair coming in the mail today which will be driven by my Xtremegamer card until I buy a DAC. I'll post an opinion as soon as possible.
[edit]Having read about these extensively prior to purchase, I can comment now that the general consensus seems to be the bass is perfectly acceptable for many although if you're the sort who thinks bass needs to be felt rather than just heard, you're going to need a sub.
It also just occurred to me that I should "burn-in" these speakers for a couple dozen hours before making any conclusions about them.
[/edit]
This is generally a very bad way to connect your headphones. Which is probably why the A5s, being rather classy units, don't provide one.
Mr. B, it sounds like we need to help you find a real subwoofer so you can have a similar experience regarding the "subwoofer" in the Z5300s.![]()
Should I put them on some rubber pads or something?
Wow I was way off in my bass apprehension. Not only is the bass more powerful and deep than the logitech x-540 subwoofer, it's far more precise! I have them about a foot away from the wall, and they vibrate my whole table. Should I put them on some rubber pads or something?
No they have a thin padding for the whole speaker bottom. I'll check out those amazon pads, thanks.Yeah, and it'll also help the sound if you get them properly isolated. Bloody sympathetic vibrations can be a nuisance.
Did they come with little stick-on feet or anything?
Ideally, the tweeters should be positioned at eye level.Wow I was way off in my bass apprehension. Not only is the bass more powerful and deep than the logitech x-540 subwoofer, it's far more precise! I have them about a foot away from the wall, and they vibrate my whole table. Should I put them on some rubber pads or something?
They sound amazing with my hsu STF-1.
