defaultluser
- Jan 14, 2006
I just recently purchased an Intel Mac Mini for use as my low-power always on computer. In the past, I have connected the audio between my two computers such that the always on machine acted as a passthru. The audio from computer 1 would go into the line-in on computer 2, and the combined audio output from computer 2 would go to the stereo.
Unfortunately, this Mac Mini is the first computer I've ever seen that couldn't do passthru. There seems to be an option under Utilities / Audio MIDI Setup to enable the audio thru, but those checkboxes are disabled.
My current solution is to use an application called Audio Recorder, and check the Monitor box. This is not an optimal solution because it a processor-hungry PPC application, and the Monitor checkbox is always unchecked by default when the program loads.
So, it is obvious the Mac can perform audio passthru, but there's no obvious way to do it without some crappy 3rd-party program. What am I missing? There has to be a better solution.
