audio over SKYPE
ezac
Hey,
Not sure if I'm posting this in the right thread, if so sorry.
I'm trying to play audio files over SKYPE to other users is that possible?
Specifically -DJing live over my machine to someone else?
Why not just use shoutcast?
I don't think it will be easy to get this to work with Skype unless you just stick the mic up to the speaker...
ok, well I'm not limited to SKYPE.
I need someone to be able to listen to what I'm doing at my end in real time. Is that even possible? Know what I mean?
Shoutcast will do?
Shoutcast will let you stream music from your media player (not sure what it works with these days, used to be Winamp) or a mic. Streaming the live audio of whatever your soundcard is doing is a bit more difficult, at least on Windows. I don't know of a good way to do that other than looping the output back to the input.
if you are looking to just stream live video (w/audio ofc) , justin.tv ustream.com are some of the websites I use.
