Posting this for a friend, he has a jet boat and wants to be able to play some tunes while on the water. Small jetboard its basically a Ski-Doo with a slightly bigger motor and the boat frame.. Not a big boat but the sound must be able to go lod enough to be heard over the engine and water. So he is interested in using an ipod, but would need some amplifier right? FYI he has a 12volt battery that he can use somehow if that helps. Thanks for any help! he needs to know what will work and speakers should be pretty small... thanks again
