Audio noob needs suggestions (please?)
Private_Ops
I'm trying to get away from my desktop and go mobile with my laptop.
Sadly I have no good headphones nor have I ever. The best thing I've ever had was a cheap pair of Sonys that I had used with gaming (also moving away from that as well, takes up to much time that I could use for something else) and I thought they sounded awsome but, they had a bit of "hollow" sound... they no longer work for some reason.
Anyway, I couldn't tell you the audio chip in my laptop (it has an Nvidia chipset). At the moment I'm looking into building a Cmoy with a TLO82 that I found locally (my god Radio Shack had a chip worth buying?!).
My priorities are mainly music. Some light gaming mixed in some where there but , gaming IS NOT a priority.
I'm not a big fan of small headphones and I need something that is decently comfortable since I wear glasses.
Since I'm still in school and don't have a real job I'm on a budget of about $100-150. Hopefully with in that price range they make something for a novice?
Suggestions and comments appreciated.
If you could splurge a little bit ($200) the Grado SR 225, Sennheiser HD 595 and Audio Technica A900 are all very good cans that will last you a long time. If those are too pricey, for $100 you could get a pair of Sennheiser HD 555.
Audio Technica 700 series either open or closed for around $100-150 or if you want to go cheap the Koss R-80 for about $40.
http://www.amazon.com/Koss-154336-R-80-Home-Headphones/dp/B00005N9D2
you will want to upgrade the source and amplification for best results. that can get complicated but check out head-fi's portable, computer audio, and headphone sections. lots to learn there.
I can get/make an amp but I'm not to sure they make PCMIA sound cards do they?
As for the 700 series. Are these any good?
http://www.newegg.com/Product/Product.aspx?Item=N82E16826402014
There are some decent USB sound cards floating around these days.
Newegg has a $30 "trade-up" rebate on the Sennheiser hd555 headphones which would bring them down to $70 which is a great deal
Don't want USB. My laptop only has 3.
So? Mine does too. A usb dac or sound card will yield the greatest improvement in sound period. You could spend whatever on the headphones and they would still sound crappy compared to a real source/amp b/c you are trying to use the laptops headphone out.
If you want something inexpensive, just get some sub-$100 headphones or iems that are REALLY easy to drive and go on down the road.
