Nazo
- Apr 2, 2002
Ok, I don't remember my playstation doing this originally, but I've had the darned thing for so many years I've already had to replace the cd spindle, the power supply, and the connectors for the controls... Curiously enough, for some odd reason I'm getting a line noise the moment I plug in the video connector, but if I unplug it the noise is gone. I tried plugging it into a VCR instead of directly into my TV, but I still get the annoying noise. I admit to not being much more than a novice when it comes to electronics (eg I know enough that I'm not scared of a few wires and resistors with a couple of volts running through, but if you asked me precicely what it is a capacitor does or how a particular chip should be wired, I couldn't really say.) Most people I know just panic at the mere thought of live wires so that if I rewire some old broken speakers or headphones, my family gets into a panic. Anyway, because of this lack of knowledge, obviously I can't just look at the PCB and figure out just how to isolate this. The only bit of information I can really give that I haven't already is that I can hook up the (well, I thought ground, but obviously not) wire that goes on the outside part of the RCA plug and get part of the video with very nearly no annoying noise, but the moment I plug in the wire that goes to the central part the noise starts. I've made an external connector (just like an extention cord and nothing more right now) which I thought to try different things with, including running it around one of those little cylindrical magnets but I just have to admit that I don't really know what I"m doing, so none of it helps. I'm hoping one of you people who do know what you are doing might just know some simple little thing that a novice like myself can do. Eg, if it involves a chip, it has to be dirt cheap (I'm broke) and something I can pick up at my local radioshack with a very simple circuitry, especially since, despite my physical science classes, I really can't remember very much about how those diagrams and all worked.
Anyway, would anyone know of a simple way to fix this? This horrible noise driving me insane. The only way I can play psx games is either get a headache and have to stop in about an hour or use emulation. And for some reason even the best emulators still are just horrible. Running too slow or with horrible video or whatever esp with 2D or hybrid games. (I'll examine this more later, but that's a seperate issue.) I think this also happened with my dreamcast but right now I'm missing the cable to find out for sure. Because of this, I think it's the TV's fault. I can't afford a new TV though.
EDIT: Ah, I just turned off my TV and it didn't stop... Howevever, I touched the audio ground to the non-central (ground?) wire on the video and it stopped instantly... I see no problems with the video, so I wonder if I should make this arrangement permanent and even rig up something to do that with on my dreamcast if it was doing it too (I prefer not to splice it's cables, but my playstation has been through so much that it's cable already was spliced.)
