Audio issue when GPU under
Ruddys
Hi.
So hoping anyone can help to guide me in the right direction.
So have been fighting with random restarts and audio issues under load for as long I have this PC.
As I got sick with covid once felt better spent time just troubleshooting to keep my head busy to avoid thinking about breathing difficulties.
So furthest I got was doing AIDA64 Stress test that made my main audio device appear and disappear constantly . Until I tried to test test each part individually.
So only when GPU is under aida64 stress test audio disappearing issues appears. Same issue happens with my rtx 2080 and recently upgraded RTX 3080 so I doubt it can be GPU itself causing the issue .Also HWinfo64 does not show current rail power and GPU rail voltage not sure if that is normal or not.
Another issue is that PC can sometimes restart without any BSOD or Error logs while gaming specific games .Far cry 6 restarts every 10min-1h mark. Then again I can play Modern warfare , Apex ,GTA 5, Metro Exodus for hours without single restart.
It passes long runs of Real Bench , 3Dmark stability test is at 98.7%
System Spec
5900x Stock
RTX 3080 Stock
ASrock x570 Taichi
32GB Viper steel at 3200mhz CL16
1tb 970 evo SSD
2x2TB HDD RAID0
Arctic Freezer II 360mm AIO
11 PC case fans ( Including 3 from AIO )
Attached HWinfo Screen Shot
And here is Google drive link to sample video of the issue
https://drive.google.com/drive/folders/1QMNFBmgXoW-nBF_a-hCxHgnyK8DqMTiK?usp=sharing
