Audio Input from a tuner card through Mic Input
alpha_23
I have an ATI Wonder TV tuner USB 2.0. I primarily want to use it play an attached gamesystem. As you probably know, ATI Multimedia center has a really bad delay, and I can't use it. Using Dscaler, I can not get sound input. The laptop I want to use this on does not have a line in. However, I do have an RCA to mini converter that works through the microphone port, however the sound quality is atrocious. So, my question is two-pronged.
1. Is there a way to get audio from my USB tuner without using ATI Multimedia Center, and
2. If that's not possible (I haven't been able to find a solution) is there a program that will clean up in real-time my mic input so it sounds like a line-in?
Thanks,
alpha_23
