Audio Help! Rumbling sound.
JLGatsby
I have a Soundblaster Live 24 bit audio card and in the past two days, wheneven music, or games hit a certain low bass note, it rumbles, or sounds like a "fuzzy" bass rumble.
Does anyone know what the problem is? I don't think it's my headphones.
Is it a physical problem on the card? Software problem? What should I do?
TIA
TIA
Well, looks like it's time you start doing some troubleshooting.
Try different headphones/speakers with the sound card.
Try your headphones out of a different source playing the same music.
