Audio drivers?
dig_em
I have a MSI VIA KT400A Chipset(KT4AV) motherboard and the soundcard is built into the mobo. It wont seem to detect my speakers or my headset when I plug them in. Do I need to get a driver? Where can I get this? I searched the MSI site and did install the 4in1 driver but that didnt fix the problem.
http://us-download.msi.com.tw/support/dvr_exe/mbd_dvr/ALC69.zip
btw, if you just now installed the 4-in-1 and have gone without other drivers for this long, then your system is probably hosed -- and I recommend a format, re-install windows, and install your drivers PROPERLY!
the 4-in-1 is crucial, and should be the very first thing you install when you get to your new desktop after a fresh install of windows!
