I've got an ASUS A8V Delux mobo with on-board audio. I only have a 2 speaker setup (with a sub, but that's routed through the speakers -- the mobo doesn't know it's there). Also headphones. So basically it's just two channel.
When ever I play a game (Half-Life 2, in particular) that has support enabled for directional surround sound, any sound effect or dialog works fine except for when it's being projected from 2
'clock (just off my right hand side, barely out of eyeshot) by player's perspective. For example, if Alyx Vance starts talking in HL2, and she either moves to my 2, or I move so that she is now in my 2, she goes completely mute. Same goes for gunfire or ambient "projectors" that the map maker may have put in (in fact I can now locate these rather easily by spinning around till they go quiet). However if there's any echo effect going on in that level, I can hear that just fine, as long as the echo bounces around to the left side, or just anywhere out of the 2
'clock.
When spinning around slowly near a constant audio source, it is full strength (100%) at any orientation, till I get to around 12 or 4, then it drops gradually as I continue to turn until it goes to full mute (0%) once it hits my 2.
I have uninstalled and reinstalled my drivers multiple times, as well as the sound management (alternative audio dashboard) software it seems to want to install as well. I've also played around with that software for weeks but have had no progress. It seems like if I could just locate a volume slide bar for that side, I could just turn it up, but I can find no such thing.
Any help trouble shooting this (and subsequently solving it) would be greatly appreciated.
Thanks in advance.
Thanks in advance.
