Audio build (special case build for live performance)
Corban227
Hey, guys, I have a unique situation I am looking to do a build for. Before I answer the standard questions, I want to explain the situation and the cases this build will be used for so that you understand. Build updated below
This build is going to be used to run audio samples for 2 to 3 Yamaha weighted 88 key keyboards. The full layout of the system is as follows:
  • Keyboard to Computer
  • Computer system interacts with keyboard through midi input
  • Output from computer to amp system
We will be using a basic sample program to pull samples from (some examples include Logic pro, main stage, reason, garage band, etc).
Traditional setups of this type use a mac book pro and one of the following programs listed above. All keyboards are run through the mac and then out to the amp system. Mainstage (being the best) allows you to assign each instrument it's own bank for live performance.
My goal is to build a cheap tower build, that can be transported over rough terrain, and plugged into a touch screen monitor to run one of these programs for the cheapest price possible.
Live performance sampling of instruments
going for as cheap as possible. aiming for the build to be 500 total
I live within driving distance of a micro center, and new eggs will call warehouse
mobo processor, ram, SSD, case, powersupply and backup battery, windows 10, touch screen monitor
none
6) Will you be overclocking?
no
doesn't matter. going for cheap cost
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
nothing in particular. just need 3 to 4 USB minimum. If price allows, it would be nice to have some sort of local wireless access via a phone or tablet
no
I hope you guys can help with this. I really need a reliable system that can be transported over all types of terrain, for cheap, that can handle this system.
I'm not going to be much help, but so others can help, some key questions:
0) are you looking for a hackintosh, or are you going to run an different os?
a) what kind of cpu and ram do you need to run this?
b) how are you planning to get MIDI into the pc (pci, pci-e, usb?)
c) how are you planning to get audio out of the pc?
Go 19" rack mount and whack it in a small rack flight case with detachable ends. Can be biffed in a car/truck/van with rest of your gear. Or things put on top, while packed or in use. Travelling and touring/packing/unloading is where your most wear/tear is. We use similar setup for high end laser projector control systems.
Do you have a link for an example? I'm not entirely sure what you mean
Also I would really appreciate it if someone could price out a build for me just so I have an idea
0) I wouldn't be opposed to trying a hackintosh/dual boot windows and hackintosh
A) minimal. 4 gigs should work
B) midi to USB
C) basic audio out. I.e. 3.5 audio jack.
had some time to do some poking around tonight. do you think I could mount the mobo and ps to a slide rack (open air essentially) and then put that rack shelf into a portable rack case? It wouldnt be a clean build persa
http://www.roadcasesusa.com/rack-cases-and-rack-mixer-cases/
Get an 18"+ deep rack there that will fit your computer case. The one you chose looks good. Just PSU I'd check that brand out for reviews and measurements, never want to go too cheap on them. Cheap seasonic would be a safer bet. But double check everything fits in 2U. Maybe go slightly bigger component case if you can.
