Audio Amplifiers
mikeblas
[H]ard|DCer of the Month - May 2006
I've been thinking about building an amplifier kit.
I'm curious about some of the circuits I see on the net. This one (PDF file) is pretty interesting.
What's the purpose of Q1 and Q2 in the channel amplifier, for example?
If you look at the benchmarks, you'll see that there's a large amount of crosstalk. Why is that? It picks up after 500 Hz or so. Does that indicate an undampened resonance in the circuit someplace?
The idea of putting an amplifier in line with the ground input (and isolating it from the batteries) seems novel to me. Is this actually common?
Head on over to http://www.head-fi.org and check out the Do It Yourself forums. There are
a lot of posts covering this, as well as quite a few helpful people that can add useful input.
-Jeff
Pick up the Randy Slone book, "High Power Audio Amplifier Design Handbook".
It's very good, and it explains almost entirely how audio amplifiers work and it has plenty of projects inside. It's a bit on the opinionated side however; ignore all the rants and other crap listed in the book about how "class A sucks, tubes suck, class G and H suck", etc... Oh, and if you build an amp, stick to emitter follower designs. :D
Also google for "leach amp", it's an extremely good solid state amplifier design and it's very well documented.
Thanks for the book, and thanks for the Leach Amp reference.
Have you built a Leach? How did it go?
Thing is, I'm building a low power ampifier, for headphones. Is the book still mostly applicable?
If you're looking for a headphone amp, you don't need anything anywhere near as fancy as the schematics already posted. I've built a CMoy (site contains parts lists, places to buy, detailed instructions with pictures, everything!) for myself, and it works great. Nice and simple. It fits easily inside an Altoids tin. If you're good, you could probably fit one in those new, slimmer Altoids tins...
Oh! If you're just building headphones, the Slone book isn't really applicable. The smallest amp in the book is 50 watts, all the way up to 600 watts. Things you don't want to plug a pair of headphones into.
Probably best stick with a typical headphone amp design. My suggestions are if you're going with something portable go with a cmoy design, and for something less than portable (you don't mind it sucking batteries) go with a BUF634 based design - something like a pimeta but without the typical "omg bias the op-amp into class A and kill its PSRR" crap. In other words, remove Q1/Q2. :D
On the high power side, I've built a couple of Slone designs, and I've built a pair of Leach designs. They're excellent.
My brother built a Leach amp, and unlike the Don Lancaster amp he built, it didn't blow up the first time he applied power. He tried all sorts of loads but could never make it oscillate, so no wonder some people use the amp to drive motors or ultrasonic washers.
Apparently over 1,000 Leach amps have been built, so the bugs have really been worked out.
I decided to build a PPA v2. I'm about 75% done, I suppose.
I built a STEPS power supply and tested it last night. I'm still short a few parts on the amplifier board (a bundle of resistors and the output transistors) so today I'll probably work on fabricating the case.
Thanks for all the references!
Erm Q1 and Q2 are odd. They are RF Transistors.(JFETs)
There is a high speed buffer on the output stage, im confused.
The JFETs could explain the crosstalk problem, or perhaps its not earthed correctly. A good amp design will have its audio ground above the powersupply negative.
I've finished ... mostly. It sounds great, though I don't have any other headphone-specific amp with which to compare it.
I've got to hook up the crossfeed, and do a little more work on the case, but the amp runs on the bench and sounds good.
