Audigy2 and Front Panel Audio
LoneWolf
Because of my audio issues with ATI's newest versions of their Multimedia Center software and NVidia Soundstorm audio, I just scored a deal on an SB Audigy 2. One thing I didn't think about, though. My new Antec P160 case has front panel audio connections for speakers and microphone. My MSI K7N2 Delta-ILSR mainboard has the connections for this, but is it possible to connect to an Audigy in the same way?
AFAIK, there are no pins on the board that natively support it.
You can always take a soldering iron to the board though.
The quick answer is---->
Nope won't happen unless you have the small header near the top of the card by the bracket.
Of course modding makes anything possible, ;)
Well I looked up the pinouts, i would just like to find a connecter that will fiit the audigy card with wires coming out i can solder rahter than hacking my audigy 2 to bits hehe.
A lot of people would ... the problem is the header in question is not found on the older Retail cards and the live drive header is all digital stuffs.
Here is the pinouts for the little header I am talking about.
If all else fails you can always smack together something that plugs into the back of the card......... like the stuff FrontX sells.
http://www.frontx.com/order1.html
I do have that header...now what?
Sorry....I just read your post. I'll try this this week. Thanks for posting it.
