Audigy vs Audigy 2 vs oboard
lordsegan
Audigy vs Audigy 2? Also, it worth using one of these boards to save on CPU overhead vs NF3 onboard sound? I heard that it is sometimes a good idea to run without any PCI cards to maximize overclocking and I don't care about sound THAT much.
PS, I currently own the Aud 1 card
I have a Audigy 2 in a NF3 mb....I rather enjoy it.. You get better framerates, and a lot of games are optimize for EAX...
how much do you game? how fast is your computer? if you don't care about sound that much than i'd stick with using the audigy 1. as far as saving overhead, you don't really gain that much but that could depend on the speed of your computer. sure, your computer has to perform some of the sound processing but you won't lose that many frames per second. Plus, would you really notice a drop from 73fps to 70?
onboard on mobo's are pretty good now-a-days. audigy 1 isn't bad. audigy 2 is where you jump the gap. i have it and i can tell a huge difference.
just depends on how much you listen to music or game. i'm always listening music on my headphones, so a good soundcard and headphones are important to me. same goes for speakers. i wouldn't pair a audigy2 with some cheap speakers or headphones.
I threw an Audigy 1 in my rig a couple a days ago to see if it would help some sound problems I was having Half Life 2 and I noticed a decent improvement in both smoothness and sound quality. I am running a 6800GT and a 64 3400+ running at 2.5 Ghz on an nforce3 DFI, so I have plenty of card and cpu.
Anyone have any benchmarks for CPU used when comparing on-board NF3 vs. Audigy 2?
I'm thinking about switching from on-board to Audigy 2...
