Audigy or X-Fi??? Vista Problems?
ACBrown
Hey guys,
I'm debating which of the two to get. Money is a little tight, so I'm hesitant to drop 100 (or more) on an X-Fi. But I've heard there are Vista issues with the SB Audigy. Is that still the case?
Is there really that big of a difference between Audigy and X-Fi?
Thanks,
Austin
If money is tight, I'd try to go for the X-Fi XtremeGamer if you can afford it. Right now it is at $81 on NewEgg (http://www.newegg.com/Product/Product.aspx?Item=N82E16829102006). But it is often on rebate to bring it down closer to $50. These week long rebates have been available typically once every 1-2 months or so.
Here (http://www.frys.com/product/5017775) is X-Fi XtremeMusic which if I recall correctly, is nearly the same as XtremeGamer. It is listed at $49 + shipping for the OEM version.
I love my ExtremeGamer, it is spectacular for the money, especially if you are coming from onboard :eek:
