First build. My case is an Antec P150 and I'm using an old Audigy (SB0090) card. My mission is to connect the front panel mic and lineout jacks to the Audigy.
After some research, I concluded that using the front panel connectors as-is isn't going to work. The only promising connector on the card is AUD_EXT, but the pin assignments (via Creative Support KB Solution ID SID3026) and various posts indicate those are digital only.
So my thought now is to route the front panel cable along the interior perimeter of the case and out through one of the intake vent holes above the expansion slot for the Audigy, using the external mic and lineout jacks on the card.
Again looking at SID3026, it shows the mic jack has power, signal, and ground connections. The lineout jack has left, right, and ground connections. I haven't done a lot of soldering, but I figure I can terminate the front panel cable with appropriate plugs and some help from Radio Shack.
Now, on the front panel cable are seven pigtails labeled mic, mic bias, gnd, fpout-l, ret-l, fpout-r, ret-r. I'm just guessing about how these match up. Can someone confirm that:
(front panel -> mic plug)
mic -> signal
mic bias -> power
gnd -> ground
(front panel -> lineout plug)
fpout-l -> left
fpout-r -> right
ret-r -> ground
ret-l -> ground
Assuming that's correct, are there any other issues to consider here? I will be using a Y-adapter on the lineout jack on the Audigy so that I can have one jack for the speaker system and another for the front panel headphones.
Lastly, in a related task, I'm trying to connect the four-pin PC_SPK header on the motherboard to the corresponding 2-pin header on the Audigy. According to the pin assignments on the motherboard, the two inside pins on the 4-pin header are ground. I'll only be connecting the +5V and SPK_OUT pins to the Audigy. Should I leave the ground pins on the motherboard alone, or do I need to do something with them?
Thanks!
mic -> signal
mic bias -> power
gnd -> ground
fpout-l -> left
fpout-r -> right
ret-r -> ground
ret-l -> ground
Thanks!
