Audigy 4 Pro
mpegripper
newegg has this for $219.99 with free shipping after $50 mail-in rebate
http://www.newegg.com/app/ViewProductDesc.asp?description=29-102-181&depa=0
i know MIR isn't the greatest, but this is better than most places charging $280 or so
WTF they are up to 4 already? anything actually good about this card?
They skipped "3." ;) LOL
Last time I checked it was nothing more then an update for the Audigy line adding very little (typical Creative game you know?), too bad they didn't add something useful like realtime DD encoding. Then again I still wouldn't touch Creative if they had, not a fan of them (to put it lightly).
The package might be great if you're a musician and do ALOT of digital editting on your computer.
from what i know the SNR is now at 113db
new version of eax, so a creative rep told me at frys yesterday
they skipped 3 because of bad luck in china or something i heard
there is a noticeable difference with the audigy 1 and the audigy 4 tho
this is on the klipsch 5.1s
only bought it because i needed the extra plugs for my headset
the audigy 4 pro is a slightly upgraded version of the audigy 2 zs platinum pro. they stuck a sticker on the chip, used different DAC's on the board and uped the signal to noise ratio. its not worth the extra money unless you are an audiophile looking for top of the line and bragging rights
they're gamer sound cards...
there's a ton of cards out there that offer way better performance/quality for musicians.
Unless something has changed, Sound Blasters are not appropriate for most recordings.
The biggest problem that I can think of is that it always resamples digital input. So if you send it a digital signal at 44.1khz, and you're recording at 44.1khz, the SB will resample it.
Musicians are far better off going with something from m-audio (which has many cards that do as much or more than the SB for the same price or less).
I have an SB for gaming, but when it comes to digital audio, I always use a cheap M-Audio. Of course my SB is an old SB Live 5.1, so it's also noisy as hell, even on the digital channels (the noise floor is around -50db, vs. > -90db on the m-audio).
Not really, unless you mean for very limited purposes. Even the best Envy24 boards, for example the M-Audio Revolution 7.1 (chosen because it has high quality I/O unlike cheaper Envy24HT-based cards), costs around $100 and only includes a single digital audio out. Capturing digital audio on that card isn't possible. When you get to the cheaper Envy24HT/-S models, you lose high quality analog recording since those cheaper cards have mediocre DACs.
Other cards with similar multiple I/O capabilities (midi in/out, coax SPDIF in/out, optical SPDIF in/out, 3 x analog line in, LL ASIO 2.0) as the Audigy 2/4 Pro line are much more expensive. The bonus is that the Audigy 2/4 Pro cards are also good for gaming. Of course these aren't great Professional cards, but they're good for the price range.
Yeah it only goes up 15db. That's it. Audigy is good for gaming because of EAX. That's about it. They are good all around cards. But surely not the best overall. Some are good for music, some are good for recording, Audigy is good for gaming.
I wouldn't justify the price of an Audigy 4. I think Creative is getting lame with their updates.
I am using a Hercules GTXP... and want a reason to upgrade.
Has creative improved their STABILITY lately? I couldnt stand Creatives BSOD's (especially on dual processor machines) EAX on my KPM 4.1's would sound pretty... But i always feel creative DRIVERS are bloatware garbage.
Maybe ill start a thread in the sound forum =)
Bleh... Whats the purpose? Gaming or htpc? I got a Herc GTXP on my little crappy htpc hooked up to my receiver and love it... If you buy one of those over priced Aud4, sell me the GTXP so I can help set up my sister at her house =)
You do realize trhat only "amateur" musicains would use a consumer level card like a Revo or Audigy, Right? As Stang said there's better cards out there.
LOL, I just upgraded to an Audigy 2 last weekend and thought, WOW, this is overkill.
I've been using an Audigy 1 for 3 years now and would see no reason to upgrade as long as it still sounds good! Would be interesting to do a side by side listening and seeing what the real life differences are.
how much difference does the sound card even make? i have a sb live right now and use it with klipsch 5.1 or headphones. do gaming and listen to music. would i even hear a difference between the live and audigy?
personally I'd get a ESI Juli@ if I had to have a PCI solution for audio recording/mixing (mainly because of its excellent design/layout and professional quality software/drivers that allow you to program your DSP chip on the Juli@ to create the proper recording parameters. But if I could afford to pay a few hundred bucks, I'd just go with firewire direct mixing device which usually supports 16+ channels instead of the 4 to 8 (depending on how you view stereo and mono) that most PCI cards can offer.
Funny, Intel also skipped the 486DX3 and went straight to the DX4, then tried to justify it by saying the old chip was officially called the "i486DX2", and that they were dropping the name i486 so the the official name would be "DX4", and that the "4" in "DX4" was not supposed to be referring to the clock like the "2" did, but instead was meant to "remind" us of "486"...Is there a pattern here? Well, I believe so in Creative's case if the products released are more evolutionary than revolutionary...I had an Audigy 1 replaced by an Audigy 2 ZS, and to tell you the truth I might as well be using the Audigy 1 since it sounds pretty much the same to me. Ironic considering how picky I am when it comes to monitors, like blurring on LCDs.
You know, in the same way, 8 is considered a lucky number in Asia, and it's a big market for airplane companies like Boeing and Airbus, who are coming out with the 787-800 and the A380-800, respectively....yet up to now, almost every model of airplane started at 100 and went up from there...So what happens when the next big thing comes out after the Audigy 4 runs its course? I'll be damned if we start seeing the Audigy 8 next! Even though it'll probably just be the same card but with 114db SNR. Man, they must've been in heaven when the 8088 processor was released!
from a sb live to an audigy is even a huge difference in my opinion, if i were you i would probably just upgraded to the audigy2 zs tho
Arctic silver went from 3 to 5 and used the same reason
let me clear up something. if that is the case, then that would be stupid. because in the chinese language, 4 = 'sae' which sounds like 'sai', meaning death. if what you said really is true, then the guys at creative must be really ignorant. some companies dont even care. nvidia ignores the number 4 (nf4) as being bad luck in asian countries, but yet it still gets manufacturered in those countries.
watch, they will come out with an audigy 99 in a month, to correct that error
99 is very good luck in chinese
I thought in Chinese culture (or maybe Japanese?) in general even numbers were bad and odd numbers were good?
Chinese would matter here since they're made in Taiwan. The number thing is kind of wierd like these. :confused:
Because Winamp 2 + Winamp 3= Winamp 5 :rolleyes:
They took the audio and skin function of 2 and the video crap of 3 and smashed it together.
As for the Audigy I think it should have been something like "Audigy2 and a half" and since they didn't really do much calling it that is a stretch. More like "Audigy-that-doesn't-really-add-much-let-some-of-you-idiots-are-going-to-buy-it-to-replace-that-Audigy 2ZS-that-you-bought-a-month-ago-because-we're-Creative" ;) (I actually know people like that, one guy bought an A2 a month before the ZS came out and then bought that as soon as he could thinking that it was "better".)
Now if it was atleast PCIe that would have been something.
so i have it installed now
and on my klipsch 5.1s it actually sounds better than my audigy 1 was, not a huge difference but definetely noticeable
i think it was worth the upgrade considering i need a pro model for the extra inputs
probably should of just got the audigy 2 zs platinum pro tho,i'm sure it would of been the same
Meh, you could have saved some money that way but from an Audigy to an Audigy 2 ZS was hardly noticable with my friends rig, I think you're probably better off with this.
I still have the Live! Platinum...It was like $200 when it came out 5 or 6 years ago...I see no reason for me to upgrade...My homemade 10" sub still makes the curtains shake with the Live! drive...
Synful Serenity said:
.........I had an Audigy 1 replaced by an Audigy 2 ZS, and to tell you the truth I might as well be using the Audigy 1 since it sounds pretty much the same to me. Ironic considering how picky I am when it comes to monitors, like blurring on LCDs.
What speakers are you using?
I know sound quality/clarity/etc. is subjective, as everyone's ears, brains, and experience is different. However, I noticed an improvement going from an A1 to my current A2zs, but I'm also feeding the card into a pair of amps, then to bookshelf stereo speakers.
Yeah, I should have added that I use headphones or an old 2.1 speaker setup. If I had a Klipsch or 6.1 or some other high setup, then I'll bet I would probably have heard a difference. I think I am pretty picky when it comes to sound as well as sight, but since I live in a condo now I usually stick to headphones.
