Audigy 2 ZS question
clickclickw00t
I was wondering if I could connect a front panel connector that you can usualyl buy with the Audigy 2 ZS Platinum to the Audigy 2 ZS.
I really need that front panel for recording things and such. My friend has one and is not using it. I was wondering if I could connect it to my Audigy 2 ZS.
Thanks
You should be able to. I put a Live Drive on my ZS 2 Gamer edition.
Thanks
Yes the A 2 ZS card is the exact same card sold with the Platnum version Audigy 2 zs
If you look at your card there is a place for the ribbon cable to connect at the end.
Again to confirm YES
There is NO differance between the 2 cards. Only differance is the Software and front panel. The Platnum usualy comes with Cubias and fruity loops.
Please, I updated the thread. If you check the link, its a front panel for a X-fi Fatality. The guy that doesnt need it is offering it to me.
Will it work on a 2ZS or no?
I would gamble and say yes.. The front panel on my platnum xfi has the same in puts and outs as my old ZS 2 platinum.
The ribbon cable just connects the SPDIF and others to the card/panel.
You may want to take this to a SB forum specific.. To make sure PIN placement is the same.
I dont have my old ZS 2 in a system right now to check for you..
I will try tomorrow if I get the time to build a system another tomorrow I will try my old ZS 2 and My new XFI face plate..
Dont rely on it though.....I may have a mile long honey do list tomorrow..
Check on a SB forum...too see if PIN placement is the same..
EDIT... If he is OFFERING it to you take it....If it doesnt work you can E bay it. Or just give it back.. :D
Well of course he is offering for a price.
What's a good price for it?
And also: wtf is a SB forum?
