Audigy 2 ZS Front panel audio
ubern00b15
Is there a way to connect my front audio ports to my audigy 2 zs? i want this so I can plug in my headphones from the front of my case. the wires for the front audio are not just headphone jacks, they originally connected directly to the mobo, and it looks like there should be a way to connect it to the audigy
do a search for audigy and my name, i posted the pinouts somewhere.
By the way, youll need to re-tail your front ports to make them work with the connector that has to be used, or make your own adaptor cable.
You posted the pinouts?
Were?
Cause I think you stole them from one of my posts. :D
