Audigy 2 ZS driver help
daphatgrant
Fi-yah!
A couple years ago I bought an Audigy 2 ZS (SB0350, CA0102-ICT) off of a forum member. When I first installed it I had issues and later found that it was an oem card or something similar in that it doesn't install in the normal fashion (regular .exe from creative doesn't work). I guess what I am asking is does anyone know how to get this thing installed, I now wish that I had written down the instructions.
If I can add any more info let me know and thanks in advance :).
A8N-SLI Premium
Win XP Pro
I had it working before but can't seem to remember how I did it. I have it playing audio now but it plays the rear channels through the front channels, I get no audio from the rears (5.1), the front and center play fine.
Could start here i guess.
http://support.creative.com/Product...ID=1&subCatID=205&prodID=4915&prodName=Audigy 2 ZS&subCatName=Audigy&CatName=Sound+Blaster&VARSET=prodfaq:pRODFAQ_4915,VARSET=CategoryID:1#Manualselection
Got to love the way creative seems to disown their old products. Seems like they make it harder than it needs to be to find support.
Well it looks like the link was too long, try to copy it to a address bar I guess.
can we please not start a rant thread, pretty please?
OP, look here:
http://www.soundblaster.com/audigylist/
from that, you've got an Audigy 2 ZS and its got a valid Creative SKU # (the Dell OEM boards get different SKUs, at least for Live!, Audigy, and X-Fi they did)
what drivers did you download, and whats the error or issue you get? (if it says unpacking failed or CRC error, try again, not all downloads happen perfectly at times :eek: (or try another mirror))
