Hello,
I just reinstalled windows and cannot find the disk that contained all the creative applications. Luckily service pack 2 had some default drivers, and i was able to update these to the current ones from that. I do not however have the creative control device that allows me to change cmss/cmss2 and my speaker settings (or change the volumes of the various channels). I believe it is EAX console. When i go and manually d/l it i get a error upon installation that a required file is missing. Checking the requirements it appears as if it requires itself to install! Anyone have a way to get this installed?
Thanks a bunch
Thanks a bunch
