Audigy 2 FP Connection?
Reikoshea
Ive already done a search and ive gotten no direct answer...
Is there away to connect a SB Audigy 2 ES (Does have the expandable thing for the drive bay connector) to the front pannel. I can solder with the best of them, so that will not be a problem. Is there any new information on this, or is it still a dead end?
Every thread i see about connecting the SB Audigy card to the front pannel audio says, "It takes some creative soldering. No one ever goes further than that. I have this really pimp case and i wanna use the front connectors, but i cant use my 5.1 and the front connectors if i use and audigy sound card. What needs to be done to get the audigy to support front pannel audio?
Makes more sense now!
Question? Why have a 5.1 card and want to use 1 input single imput speaker set up? Unless its has Spdif in front? What speakers you running?
oh no, thats not it, I want the front pannel so i can hook my head phones up at lan parties. It gets a little annoying to try to reach around the case from when im gonna do the DJ thing to when im about to listen for the head shots in urban terror. I did however find the way to do it on devhardware. I do thank you for your prompt attention.
This comes up pretty often. MisterX, do you want to post your pic of the pinouts? Do you think I should put it in the FAQ?
GodsMadClown said:
Is this pinout consistant for Live! - A2 ZS?
Only the OEM Audigy and Audigy2 cards have that header
GodsMadClown said:
Do you think this question is "frequently asked"?
Does once a week qualify?
Cause the same question gets asked about once a week. ;)
Are you sure about that? I've bought an Audigy 2 ZS Gamer and an Audigy 2 ZS Platinum from newegg on seperate occasions, both full retail boxed, and both have the white header on them. Even the picture on the front of the box shows the header.
