Hey,
I have an Abit KW7 mobo, and an Antec Truepower 2.0 400W PSU. In the instructions for the PSU, it says to separate the 4-pin connector from the the 20-pin connector if your mobo has a 20-pin connector. Anyway, since my mobo is 20-pin, I separated this connector and it plugged right it. However, I see a 4 pin connector next to this main ATX power connector. It has the same shaped holes as the 4-pin I separated, but they do no line up right. I also have another 4-pin connector coming out of the PSU with a similar connector, but it also will not line up correctly with the mobo connector. My question is, am I supposed to be using this connector, or what? I have read both manuals, but I am still unclear about this. Thanks!
