- Mar 30, 2008
Is there any difference between ATX and mini-ITX as far as the distance the memory DIMM modules are from the CPU socket? If all four (or two for ITX) memory slots are filled - say for a Z87 chipset board - would there be any difference in air CPU cooler clearance to the closest memory module?
I'm trying to decide on an air cooler for my new ITX build but I'm getting conflicting reports how a cooler will fit on ATX but not ITX. The Zalman CNPS8900 Quiet does well in tests and is cheap but reports are it won't fit in some mini-ITX boards because it will hit the first DIMM.
If there is no difference it should fit with my low-profile ram. Right?
