My main computer has been havin some issues.....
sometimes when I try to turn on the computer, by powering it, the fans kinda jus kick on for a split sec and jus lose it. And the mobo starts beeping. I gotta keep messin w/ the power for it to eventually kick bak on. And another issue that happened was w/ my waterpump. When I turned on my computer, the pump wouldn't go. My friend says that pump requires around 12V to get a jump start, but once its runnin, it runs lower voltage. I guess that could be a reason why it was messin up.
But now the issue is..... the actual voltage shown. I eventually got my comp to boot up again fully workin. I use MBM to monitor my comp. My friend told me to check the voltage readings on that program. To my surprise, my ATX 12.0 is running 6.84 volts! Everything else is normal, just the 12V. 3.3 is running 3.30. 5.0 is running 5.15. AGP VDDQ is runnin 1.73. MBM says 1.60 shoudl be the normal, so I guess its not good?
Does this mean my PSU is fcuked? The comp is up n runnin rite now, but it started fcuking up after i accidentally standby and tried to turn it back on. I guess the comp jus didn't get the voltage it needed. If the PSU is fcuked, I'll try n get a new one, but
