ATX Mobo backplates
paco
I need a backplate for my Gigabyte motherboard that will fit in a standard ATX case. Any suggestions on where I can find one?
They're called "I/O plates"... Anyways, your mobo should come with one in the first place, unless you lost it...
You can possibly find some online, just search around and make sure it matches your MOBO. And yeah, if you bought it new it should come with one. If it didn't, return it.
Thank You!!! I don't know why I couldn't think of the name of them! It was bugging me all night. Now I can do a proper search for them.
I bought the mobo from a guy online and he didn't send it with it.
