ATX Connectors
wicked_chicken
Is anyone familiar with a good place to buy colored ATX connectors? I realize they are molex parts, but it seems like I either have to order 100 of them in a batch, or they don't have the specific connector I'm looking for.
Any help would be great!
-Wicked
Can you specify exactly what you are looking for? Also are you looking for genuine molex or cheap clones? Finally do you need any other electronic bits?
Mouser have the genuine molex parts (at least the ones I looked up) in one off quantities but they are a bit pricey and it you don't want anything else the small order charges are likely to be rather steep. For cheap clones you probablly want to look at modding sites like frozencpu
