atx/clear case plans/ schematics?
Mach5
Search is Dead, and the faq doesnt mention it, but I am thinking of building my own acrylic case and was wondering if there are any links to some sort of plans or rough specs as to where everything should go, sizes, best way of joining the sides and tops, etc. ? Any and all help is greatly appreciated.
Thanks,
Mach5
so 1/8" isnt ging to cut it for a case? too thin and flimsy eh?
Thanks for the info.
schematics anyone?
Mach5
Thanks,
Mach5
the faq doesnt mention it?? You didnt look hard enough
Originally posted by FLECOM in *** Case-Mod FAQ *** Read This BEFORE asking questions!
ATX case specifications (for building custom cases)
dimensions specified for ATX, FlexATX, MicroATX, NLX and SFX.
http://www.formfactors.org/developer/developer_resources.htm
But yes, 1/8" isnt going to really cut it if you plan on making a completely acrylic case. 1/4" is your best bet
the only problem with the ATX specs from formfactors.org is it does not tell you the correct height and spacing for the PCI/AGP cards. also you need to account for standoff height.
