Atx Case for New Build
foxslink
I have the original Fractal Arc Midi and I really like it. The Midi R2 just improved upon the previous design. If I had to choose between the two you linked I would go with the Fractal again. I like the clean smooth lines, subtle features and it's ease of use.
Case selection is very subjective. Generally cases are going to provide you with a lot of the same features, cooling ability, looks, etc. If you are just looking for a new case, then find the couple of features you want and choose the one that looks the best to you. If there is something very specific you are looking for then you need to let the community know, there is a wealth of knowledge here, but you need to let us know.
OK the case should have removable, washable air filters.I don't care about fancy lights or looks. I want a case to sit quietly and discreetly off to the side and not draw attention to themselves. After all, I want to pay attention to what's on my monitors. I want a case that supports several large (at least 120mm, preferably 140mm) case fans. I also want all the front panel buttons, audio and USB ports up near the top because my case sits near the floor and I don't want to get on my hands and knees just to see which port to plug my headphones into. I like a side panel window so I can inspect the interior for dust build up and spinning fans without having to open the case up.
Sadly, i cant get a case in the US because shipping is costly, i will have to buy it here in Chile, i found this Thermal g41 which looks nice: Thermaltake G41 (Window) (CA-1B4-00M1WN-00)
there's a similar g42, i think only front panel design changes Thermaltake Commander G42 (CA-1B5-00M1WN-00)
i bought 2 140 mm fans so the only issue is that i cant put them in this case, maybe just one, shouldve bought 2 120mm. (they dont sell fractal or Phanteks here)
what do you think? should i go with this G41 case and sell the 140mm here to then get 120mm, or should i find another case that supports 2 140 mm fans ?
I dont know if there's too much difference between 120 and 140 when moving air, or if its worth the hassle.
in case you think a better case is better idea i will post some links of Chilean Stores, pls help me try to find one with all of this in mind
Gabinetes » SoloTodo
TT Chile
Gabinetes
PC Factory • Tu Centro Tecnológico
WEI CHILE - Gabinetes s/ Fte Poder
Looking forward to hearing from you
140mm fans typically move more air with less noise. 140mm fans were slowly beginning to supplant 120mm as the standard by which most cases support similar to how 120mm replaced 80mm, but since the explosion in popularity of all-in-one liquid coolers that used 120mm fans, 120mm fan ports remain the standard. there are quality 120mm fans that can move as much air as a typical 140mm while being as quiet as a 140mm. the noctua fans are one such brand but expect to pay a premium price for them. luckily for you the ad is incorrect in describing what fans the cases support. both cases you linked support 140mm fans at the top. both cases are also well liked by buyers here in the states.
The Corsair 650D is what I believe is the best mid-tower ATX case ever constructed: steel with aluminum face, many filters, tons of storage space, great wiring hiding, built-in external SATA port. Only drawback is USB 3 front ports have type A connectors but even that can be upgraded with a 350D front port that has a 20 pin connector (buy from Corsair direct for $10).
Just a little more than you want to spend but it is well worth it!
Corsair Obsidian Series 650D (CC650DW-1) Black Steel structure with black brushed aluminum faceplate ATX Mid Tower Computer Case-Newegg.com
Don't disagree with ya, but can he get it in Chile? From the sites he listed there aren't as many options available as we have here state side.
the size of the v71 and of the other two thermaltake cases are vastly different so at this point it would be nice to know what kind of hardware you intend to build with. the first two thermaltake cases are essentially the same case just with different front bezels. they are pretty much standard, good quality mid atx case good for mid range builds. the v71 case is a different animal all together. its a much larger case with space intended for high end water cooling and multi video card setups. its up to you what to buy but if you're only piecing together a simple build, the added cost of the v71 is money spent for no benefit.
HEy guys, I just saw that Aeropost, shipping service from US, is selling the Phanteks Enthoo PRO M Acrylic at 133 dollars with shipping included, plus taxes
https://www.amazon.com/Phanteks-Ent...&qid=1474513017&sr=1-3&keywords=phanteks&th=1
it might take at least a week for them to have it in my doorstep but i think its worth the price, i sent them an email because they were selling Fractal Design Define S at almost 100 bucks more, and its nearly the same measures than Phanteks, odd isnt it? i hope they have a positive answer and if the price is right i will buy the Phanteks, there are 2 versions, acrylic and normal window, which might be better?
smaller window: https://www.amazon.com/Phanteks-Ent...&qid=1474513017&sr=1-3&keywords=phanteks&th=1
This is by far the best bang for the buck right now, considering that Thermaltake G41/G42 costs around 84 USD here, and TT Core V71 is 180 USD
WHat do you think?
I would say if you are going to go with a full liquid cooling build go for the bigger window. That way you can see all your rads, pumps and reservoirs. If you are going to do an air build then go for the smaller window, no real need to see all that dead space up front.
the 540 supports 140mm fans front and rear.
at this point i don't think there's any need to ask us what you should buy, as the amount of hardware you intend to install in the case has not been mentioned. its really all about aesthetics and only you can determine what you like and what you're willing to spend.
your build doesnt appear to be very complicated. if you're not water cooling then i see no reason other than looks to go with the large thermaltake, corsair, or phanteks cases. the small thermaltake cases would suite you just fine. if you do intend to water cool then the more expensive cases are a must.
I would wait for the Phanteks IMO. They make great cases and you'll find building in them to be very easy.
I would hold out for the NZXT S340 Elite, best case IMHO....
