ATX 20 Pin Power
Odigo
Are 20 pin power connectors compat or do I need to buy a 20 to 24 convertor?
You can use a 20-pin power supply with a board that has a 24-pin most of the time. Xeons and dual AMDs require the 24-pin purely for power reasons. On an AMD64 or LGA775 board, if your power supply has enough wattage it's fine. I wouldn't recommend anything below a 400 watt though.
For some reason when I try to turn on the computer that I'm building the computer wont get power. Only a brieif second the fan will run then stop. Im using a 20 pin connector. Any ideas?
