Attempting to send Results
XSNiper
anyone ever has this message stay on the icon when you hover over it? Ever since I "finished" the 7500 step WU nothing has been moving along correctly. I'm wondering if I shut my computer down in the middle of the transmission and it ruined it or something...I had about 720 points before I finished it, now I have only 750....weird
You need to check in your log file just exactly which protien you where folding.
The only thing the 7500 steps tell you is how many times it loops before its finished.
The points per protien can range from a minimum of 17 up to a maximum of 600.
Protien values can be found at http://vspx27.stanford.edu/psummary.html .
Also check in you log file did the core shut down ok or did you get an early end.
After that check that the work unit got sent back ok.
Luck............ :D
[14:37:30] + Attempting to send results
[14:39:05] - Server reports digital signature does not match.
[14:39:05] (May be due to corruption during network transmission or a corrupted file.)
[14:39:05] Could not transmit unit 04 to Collection server; keeping in queue.
Aww man.
I have same issue.. not runing console version... is something messed up at stanford
I had that happen on one of my borgs earlier. I used the -send all flag and it went right on through though.
