Attaching temperature probes.
Hi,
If I was using an A8N-SLI deluxe, a 4000+ and an XP-120, how would i attach the thermal probes from my aerocool gatewatch to correctly list CPU temperature?
Also, if I had leadtek 6800 ultra, would the temperature be shown in the nvidia properties, or do I have to attach another thermal probe to that, if so where on the graphics card?
As always, thank you very much for any help provided.
f
Is it a thermistor on a wire? The place it touching the CPU core, beneath the heatsink but not between the cpu and heatsink or otherwise wedgig it if possible with some tape.
It is like a metal tab which you secure with tape....
So where do I put it, can you explain more clearly?
thanks
f
i got a picture!!!
you can epoxy it on btw. right to the side of the ihs.you should be able to sneak it in there on the side.
