Hello all,
What should I use to attach temp sensors cpu/gpu/hd that came with a Koolance 720 ATX system?? I don't think I want to use thermal epoxy because it'll be a pain to take it off and possibly damage the sensor in the process. Electrical tape is too week, it'll probably give in after couple of months. I'm using Polarflo water block cooling off an Athlon 64 FX-55. There's barely any room to shim it between the water block and the cpu and the socket.
Any ideas or suggestions would be much appreciated.
Here's the water block i'm using.
http://www.polarflo.com/index.asp?PageAction=VIEWPROD&ProdID=54&HS=1
