Definitely not worth it. See all of the above.
Unlimited on Verizon though.. that's still worth something. I'm sticking to mine as long as I can. They can't throttle users on LTE, only on 3G and they only do if you're within the top 5% of bandwidth users on that tower and only for the amount of time that the tower/network is congested (not until the next billing cycle).
This is what AT&T should be doing. That's an effective network management tool. Throttling arbitrarily is just an obvious money grab.
Yup, they make that obvious by putting their soft "cap" right in between their two bottom tiered data plans (2GB plan and 4GB plan). Also, when you're on those tiered plans, they don't throttle you once you've passed your allotment, they just charge you another $10 for every additional GB over your plan.
I don't see how they think that's a good strategy. If their subscribers start noticing that, it most likely isn't going to make them move to their tiered plan, it will most likely cause them to change carriers (either to Sprint for unlimited data or anything else just out of spite).
I went from Sprint to Verizon -- scored the double data package, 10GB a month for 50 dollars.
Yes, that's high, but the speed is awesome I <3 LTE.
Granted I don't steam movies or anything so I should be good, I think the most I used last month was 2GB. Loving verizon so far.
Is there really nothing that can be done legally against the ATT assholes changing this crap after so many years paying for their service?
