retardude48
- Oct 30, 2007
I have an Atrix case with 2 fans (120mm on side and 90mm on back). The case has a filter on the side and the top which doesnt allow air to move more freely. There is not any detailed information about the case fans and how much air it moves. I want to upgrade all the fans and add an additional one to the top of the case for better ventilation. The problem lies in getting the filters off and the case fans off. The 120mm lies on side panel behind the filter so its not pulling as much air as it can. Now the fan is screwed down the opposite way, screw head facing the outside of the panel and the ends facing the inside of the case. Another concern is adding the top case fan. I did a google search and see that an 80mm fan could be added to the top but the website was in a different language and I'm not too comfortable with that information being correct. If anyone has this case, please reply back or if you have any helpful suggestions as to getting the fan off is appreciated. Also, can someone recommend 120mm,90mm, and 80mm that is quiet but hauls a lot of air (0-25dBA and 40-110CFM)
Link on newegg to my case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811209029
