Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
thats awesome....i havnt used ATI tool since 0.0.21 eather...then i had my 9600pro....then i got my 6800GT then i started flashing...software overclocking was nice is you set profiles in the tool like...ctrl+O = Overclock...ctrl+U= underclock ( say your going to bed and want to save some life ( or heat)
a overclocking utility..i dont think there is...they usually come with your motherboard...but if you want info on your CPU..thats the other part that ATI tool does...the program for your COU would be CPU-z cool little program tells you everything about them
