Jul 30, 2006 #1 V Volume 2[H]4U Joined Jan 17, 2004 Messages 4,010 I understand that CLI.exe is an ATI-related process that runs in the background. Is it normal that there are 3 running at once? If you don't know what I'm talking about, go to your Task Manager and check how many of those you have running.
Jul 30, 2006 #2 T Tytanium Limp Gawd Joined Jul 2, 2004 Messages 378 Yes, it is. Unless you're running Catalyst A.I., then you don't need it and can disable it in msconfig. CCC starts up its own runtime now, in case you need to go to the control panel, so no worries there.
