*The main reason I'm doing this is because i am intrigued by the performance hit the 4870x2 got when Quality AA mode was enabled whereas the GTX295 did not, you can check it out on the original article by HOCP HERE*
I just loaded up one small area and took a few pictures, all the way from 8xAA to no AA in quality and standard mode (Adaptive and normal) settings used were:
AA @ 8x Edge detect selected from the drop down box. (24x Effective)
Adaptive Anti-Aliasing @ QUALITY Slider (moved to the right)
pictures are taken @ 1920x1200
you can browse the flickr i set up while doing this, and while the room is dark I'm probably going to try to do this on a brighter place in FC2, AC, and maybe grid if it doesn't crash on me.
Post your own pictures/info about Quality AA vs Normal AA.
Drivers used:
Drivers used:
Code:
Driver Packaging Version 8.561-081201a1-072276C-ATI
Catalyst® Version 08.12
Provider ATI Technologies Inc.
2D Driver Version 7.01.01.849
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version 7.14.10.0630
OpenGL Version 6.14.10.8304
Catalyst® Control Center Version 2008.1201.1504.27008
