Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
No they are about the same. How much are you willing to spend? unless you dont game (and even then... they are both crap)... then dont get either of these.
Edit: if you want a cheap good card about the same price range as the gf 4 mx440 this one if MUCH better because it has 128 bit ram and the same core speed (gf 4 and radeon 9200se both have 64 bit ram, so basically this doubles the throughput of the ram, and is a higher clock as well!).
