Okay, so whenever I start up my computer, I get a BSOD generally right after the green slider that shows the computer is loading Windows. It's a 0x116 error, and it lists atikmpag.sys as the offending file. I've been having this problem for the last few days, and I'm running out of patience (and options) to fix it. So I'm asking for help here.
Here's what I've done so far:
-Overlaid 10.9 Cats with 10.10e. Didn't work.
-Used Driver Cleaner to start over (and to save typing, did so after every driver-related step from here on out).
-Installed 10.10 Cats (APP version), then installed WinUpdate ATi driver.
-Installed WinUpdate Driver, then installed 10.10 Cats.
-Installed just 10.10 (APP version) Cats.
-Installed 10.11 (APP version) Cats.
-Installed 10.11 Cats
-Installed 10.11 driver, without CCC.
-Switched PCI-E power rail
-Re-seated Video Card
-Installed just WinUpdate Driver
-Tried to revert to 10.9 Cats, can't find INF file during installation.
-Re-installed 10.11 Cats.
And that's where I'm at now. So.. where do I go from here?
System Specs:
Intel E7200 (2.53GHz) C2D CPU
Gigabyte GA-P35-DS3P Rev 2.0 Mobo
4GB DDR2-800 RAM
Sapphire ATi HD 5850 Video Card
850W Corsair Power Supply
Windows Vista 64-Bit
Nothing is overclocked.
System Specs:
4GB DDR2-800 RAM
